Ana içeriğe geç
Razer Phone Motherboard Replacement
Neye ihtiyacın var
  1. Razer Phone Motherboard Replacement, Display Assembly: adım 1, 3 resimden 1. Razer Phone Motherboard Replacement, Display Assembly: adım 1, 3 resimden 2. Razer Phone Motherboard Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    FixBot'a Sor
    Yorum Ekle
  2. Razer Phone Motherboard Replacement: adım 2, 2 resimden 1. Razer Phone Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
    FixBot'a Sor
    Yorum Ekle
  3. Razer Phone Motherboard Replacement: adım 3, 3 resimden 1. Razer Phone Motherboard Replacement: adım 3, 3 resimden 2. Razer Phone Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Razer Phone Motherboard Replacement: adım 4, 2 resimden 1. Razer Phone Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Razer Phone Motherboard Replacement: adım 5, 3 resimden 1. Razer Phone Motherboard Replacement: adım 5, 3 resimden 2. Razer Phone Motherboard Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    FixBot'a Sor
    Yorum Ekle
  6. Razer Phone Motherboard Replacement: adım 6, 2 resimden 1. Razer Phone Motherboard Replacement: adım 6, 2 resimden 2.
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    FixBot'a Sor
    Yorum Ekle
  7. Razer Phone Motherboard Replacement, Battery: adım 7, 3 resimden 1. Razer Phone Motherboard Replacement, Battery: adım 7, 3 resimden 2. Razer Phone Motherboard Replacement, Battery: adım 7, 3 resimden 3.
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
    FixBot'a Sor
    Yorum Ekle
  8. Razer Phone Motherboard Replacement: adım 8, 2 resimden 1. Razer Phone Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
    FixBot'a Sor
    Yorum Ekle
  9. Razer Phone Motherboard Replacement: adım 9, 3 resimden 1. Razer Phone Motherboard Replacement: adım 9, 3 resimden 2. Razer Phone Motherboard Replacement: adım 9, 3 resimden 3.
    • Peel off and pull out the elastic tabs at the bottom of the battery.
    FixBot'a Sor
    Yorum Ekle
  10. Razer Phone Motherboard Replacement: adım 10, 2 resimden 1. Razer Phone Motherboard Replacement: adım 10, 2 resimden 2.
    • Carefully use the Jimmy to wedge the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
  11. Razer Phone Motherboard Replacement, Rear Camera: adım 11, 2 resimden 1. Razer Phone Motherboard Replacement, Rear Camera: adım 11, 2 resimden 2.
    • Remove the one 2.5 mm screw with the Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  12. Razer Phone Motherboard Replacement: adım 12, 3 resimden 1. Razer Phone Motherboard Replacement: adım 12, 3 resimden 2. Razer Phone Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the protective peel covering the rear cameras using your hands.
    FixBot'a Sor
    Yorum Ekle
  13. Razer Phone Motherboard Replacement: adım 13, 1 resimden 1.
    • Use the tweezers to remove the white tab connector.
    FixBot'a Sor
    Yorum Ekle
  14. Razer Phone Motherboard Replacement: adım 14, 1 resimden 1.
    • Grab and remove the metal tab with the tweezers.
    FixBot'a Sor
    Yorum Ekle
  15. Razer Phone Motherboard Replacement: adım 15, 3 resimden 1. Razer Phone Motherboard Replacement: adım 15, 3 resimden 2. Razer Phone Motherboard Replacement: adım 15, 3 resimden 3.
    • Grab the connectors with the tweezers and gently lift the connectors loose.
    FixBot'a Sor
    Yorum Ekle
  16. Razer Phone Motherboard Replacement: adım 16, 2 resimden 1. Razer Phone Motherboard Replacement: adım 16, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  17. Razer Phone Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the one 2.5 mm screw underneath the connectors with the Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  18. Razer Phone Motherboard Replacement: adım 18, 3 resimden 1. Razer Phone Motherboard Replacement: adım 18, 3 resimden 2. Razer Phone Motherboard Replacement: adım 18, 3 resimden 3.
    • Grab the loose connectors with a tweezer and gently remove the rear camera unit from the phone.
    FixBot'a Sor
    Yorum Ekle
  19. Razer Phone Motherboard Replacement, Motherboard: adım 19, 1 resimden 1.
    • Grab and remove the blue connector with the tweezers.
    FixBot'a Sor
    Yorum Ekle
  20. Razer Phone Motherboard Replacement: adım 20, 2 resimden 1. Razer Phone Motherboard Replacement: adım 20, 2 resimden 2.
    • Remove the five 1 mm screws holding down the gold antenna line brackets to the motherboard using the Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  21. Razer Phone Motherboard Replacement: adım 21, 2 resimden 1. Razer Phone Motherboard Replacement: adım 21, 2 resimden 2.
    • Remove the 2.5 mm screw next to the front-facing camera with the Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  22. Razer Phone Motherboard Replacement: adım 22, 2 resimden 1. Razer Phone Motherboard Replacement: adım 22, 2 resimden 2.
    • Remove the four gold antenna line brackets with the tweezers.
    FixBot'a Sor
    Yorum Ekle
  23. Razer Phone Motherboard Replacement: adım 23, 1 resimden 1.
    • Using the tweezers remove the SIM card tray from the body of the phone.
    FixBot'a Sor
    Yorum Ekle
  24. Razer Phone Motherboard Replacement: adım 24, 1 resimden 1.
    • Carefully lift up the motherboard away from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Todd
188 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 üyesi
CPSU-WHITE-W19S19G6
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 44
Her zaman: 2,093
