Ana içeriğe geç
Razer Phone Rear Camera Replacement
Neye ihtiyacın var
  1. Razer Phone Rear Camera Replacement, Display Assembly: adım 1, 3 resimden 1. Razer Phone Rear Camera Replacement, Display Assembly: adım 1, 3 resimden 2. Razer Phone Rear Camera Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
  2. Razer Phone Rear Camera Replacement: adım 2, 2 resimden 1. Razer Phone Rear Camera Replacement: adım 2, 2 resimden 2.
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Rear Camera Replacement: adım 3, 3 resimden 1. Razer Phone Rear Camera Replacement: adım 3, 3 resimden 2. Razer Phone Rear Camera Replacement: adım 3, 3 resimden 3.
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Rear Camera Replacement: adım 4, 2 resimden 1. Razer Phone Rear Camera Replacement: adım 4, 2 resimden 2.
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Rear Camera Replacement: adım 5, 3 resimden 1. Razer Phone Rear Camera Replacement: adım 5, 3 resimden 2. Razer Phone Rear Camera Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
  6. Razer Phone Rear Camera Replacement: adım 6, 2 resimden 1. Razer Phone Rear Camera Replacement: adım 6, 2 resimden 2.
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
  7. Razer Phone Rear Camera Replacement, Battery: adım 7, 3 resimden 1. Razer Phone Rear Camera Replacement, Battery: adım 7, 3 resimden 2. Razer Phone Rear Camera Replacement, Battery: adım 7, 3 resimden 3.
    Satın Al
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
  8. Razer Phone Rear Camera Replacement: adım 8, 2 resimden 1. Razer Phone Rear Camera Replacement: adım 8, 2 resimden 2.
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
  9. Razer Phone Rear Camera Replacement: adım 9, 3 resimden 1. Razer Phone Rear Camera Replacement: adım 9, 3 resimden 2. Razer Phone Rear Camera Replacement: adım 9, 3 resimden 3.
    • Peel off and pull out the elastic tabs at the bottom of the battery.
  10. Razer Phone Rear Camera Replacement: adım 10, 2 resimden 1. Razer Phone Rear Camera Replacement: adım 10, 2 resimden 2.
    • Carefully use the Jimmy to wedge the battery out of the phone.
  11. Razer Phone Rear Camera Replacement, Charging Port: adım 11, 2 resimden 1. Razer Phone Rear Camera Replacement, Charging Port: adım 11, 2 resimden 2.
    • Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
    • There are a few gold brackets under some of the screws. Make sure to remove these and keep them for reassembly.
  12. Razer Phone Rear Camera Replacement: adım 12, 2 resimden 1. Razer Phone Rear Camera Replacement: adım 12, 2 resimden 2.
    Satın Al
    • Grab hold of the blue connector on the upper left side of the phone with the tweezers.
  13. Razer Phone Rear Camera Replacement: adım 13, 2 resimden 1. Razer Phone Rear Camera Replacement: adım 13, 2 resimden 2.
    • Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
    • Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
  14. Razer Phone Rear Camera Replacement: adım 14, 1 resimden 1.
    • Using the tweezers, grab the detached charging port and ribbon.
  15. Razer Phone Rear Camera Replacement, Rear Camera: adım 15, 2 resimden 1. Razer Phone Rear Camera Replacement, Rear Camera: adım 15, 2 resimden 2.
    • Remove the one 2.5 mm screw with the Phillips #000 screwdriver.
  16. Razer Phone Rear Camera Replacement: adım 16, 3 resimden 1. Razer Phone Rear Camera Replacement: adım 16, 3 resimden 2. Razer Phone Rear Camera Replacement: adım 16, 3 resimden 3.
    • Remove the protective peel covering the rear cameras using your hands.
  17. Razer Phone Rear Camera Replacement: adım 17, 1 resimden 1.
    Satın Al
    • Use the tweezers to remove the white tab connector.
  18. Razer Phone Rear Camera Replacement: adım 18, 1 resimden 1.
    • Grab and remove the metal tab with the tweezers.
  19. Razer Phone Rear Camera Replacement: adım 19, 3 resimden 1. Razer Phone Rear Camera Replacement: adım 19, 3 resimden 2. Razer Phone Rear Camera Replacement: adım 19, 3 resimden 3.
    • Grab the connectors with the tweezers and gently lift the connectors loose.
  20. Razer Phone Rear Camera Replacement: adım 20, 2 resimden 1. Razer Phone Rear Camera Replacement: adım 20, 2 resimden 2.
  21. Razer Phone Rear Camera Replacement: adım 21, 1 resimden 1.
    • Remove the one 2.5 mm screw underneath the connectors with the Phillips #000 screwdriver.
  22. Razer Phone Rear Camera Replacement: adım 22, 3 resimden 1. Razer Phone Rear Camera Replacement: adım 22, 3 resimden 2. Razer Phone Rear Camera Replacement: adım 22, 3 resimden 3.
    • Grab the loose connectors with a tweezer and gently remove the rear camera unit from the phone.
Sonuç
Kenny Lau
182 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 üyesi
CPSU-WHITE-W19S19G6
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,324
