Ana içeriğe geç
Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement
Neye ihtiyacın var
  1. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement, Front Plates: adım 1, 3 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement, Front Plates: adım 1, 3 resimden 2. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement, Front Plates: adım 1, 3 resimden 3.
    • Using an opening tool, pry off the the outer front plate.
    • It might take a bit of wiggling and time to loosen it and get it off.
    • Once the front plate is loose, pull it off.
  2. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 2, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 2, 2 resimden 2.
    • Using an opening tool, pry off the the handle grips.
    • It might take a bit of wiggling and time to loosen and get them off.
    • Once they're loose, pull off the handle grip plates.
  3. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 3, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 3, 2 resimden 2.
    • Using an opening tool, pry off the Xbox logo plate.
    • Once it's loose, pull off the Xbox logo plate.
  4. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement, Midframe: adım 4, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement, Midframe: adım 4, 2 resimden 2.
    • Remove ten 9 mm screws from the controller using a Phillips #000 screwdriver.
  5. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 5, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 5, 2 resimden 2.
    • Using an opening tool, pry off the backplate of the controller. It should come off relatively easily.
    • If it is struggling to come off, you might have missed a screw. Make sure you have removed all screws.
  6. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement, ABXY Buttons: adım 6, 3 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement, ABXY Buttons: adım 6, 3 resimden 2. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement, ABXY Buttons: adım 6, 3 resimden 3.
    • Look at the inside of the inner front plate and where the ABXY buttons are. Pop off the back of the piece that pushes the buttons.
  7. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 7, 3 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 7, 3 resimden 2. Razer Wolverine V2 Chroma RZ06-0401 ABXY Buttons Replacement: adım 7, 3 resimden 3.
    • The buttons should come out easily once the previous piece is removed.
    • By tilting the controller they should fall out, or you can push them out yourself if that did not happen.
    • You are now able to clean the buttons and the area around it (if necessary), and slide the new buttons back into place.
Sonuç
Kaylin
434 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Botvin Spring 2024 UMass Dartmouth, Team 6-3, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 103
