Ana içeriğe geç
Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement
Neye ihtiyacın var
  1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Front Plates: adım 1, 3 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Front Plates: adım 1, 3 resimden 2. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Front Plates: adım 1, 3 resimden 3.
    • Using an opening tool, pry off the the outer front plate.
    • It might take a bit of wiggling and time to loosen it and get it off.
    • Once the front plate is loose, pull it off.
  2. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 2, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 2, 2 resimden 2.
    • Using an opening tool, pry off the the handle grips.
    • It might take a bit of wiggling and time to loosen and get them off.
    • Once they're loose, pull off the handle grip plates.
  3. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 3, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 3, 2 resimden 2.
    • Using an opening tool, pry off the Xbox logo plate.
    • Once it's loose, pull off the Xbox logo plate.
  4. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Midframe: adım 4, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, Midframe: adım 4, 2 resimden 2.
    • Remove ten 9 mm screws from the controller using a Phillips #000 screwdriver.
  5. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 5, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 5, 2 resimden 2.
    • Using an opening tool, pry off the backplate of the controller. It should come off relatively easily.
    • If it is struggling to come off, you might have missed a screw. Make sure you have removed all screws.
  6. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, D-Pad: adım 6, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement, D-Pad: adım 6, 2 resimden 2.
    • Look at the inside of the inner front plate.
    • Where the curtains are, pop off the back of the piece that pushes the buttons.
  7. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 7, 3 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 7, 3 resimden 2. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 7, 3 resimden 3.
    • Remove three 5 mm screws from the D-pad using a Phillips #000 screwdriver.
  8. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 8, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 D-Pad Replacement: adım 8, 2 resimden 2.
    • Remove the D-pad.
Sonuç
kfrey
97 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Botvin Spring 2024 UMass Dartmouth, Team 6-3, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 79
