Ana içeriğe geç
Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement
Neye ihtiyacın var
  1. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement, Front Plates: adım 1, 3 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement, Front Plates: adım 1, 3 resimden 2. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement, Front Plates: adım 1, 3 resimden 3.
    • Using an opening tool, pry off the the outer front plate.
    • It might take a bit of wiggling and time to loosen it and get it off.
    • Once the front plate is loose, pull it off.
  2. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement: adım 2, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement: adım 2, 2 resimden 2.
    • Using an opening tool, pry off the the handle grips.
    • It might take a bit of wiggling and time to loosen and get them off.
    • Once they're loose, pull off the handle grip plates.
  3. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement: adım 3, 2 resimden 1. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement: adım 3, 2 resimden 2.
    • Using an opening tool, pry off the Xbox logo plate.
    • Once it's loose, pull off the Xbox logo plate.
Sonuç
Kaylin
434 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Botvin Spring 2024 UMass Dartmouth, Team 6-3, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 48
