Ana içeriğe geç
Razor A Handle Grips Replacement
Neye ihtiyacın var
  1. Razor A Handle Grips Replacement, Handle Grips: adım 1, 2 resimden 1. Razor A Handle Grips Replacement, Handle Grips: adım 1, 2 resimden 2.
    • If the scooter does not already have handle grips, skip to step 2.
    • Locate the handle grips at the upper ends of the T-tube.
    • Be careful to keep the scissors away from your other hand while cutting the handle grips.
    • Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
    • Repeat for the other handle grip.
  2. Razor A Handle Grips Replacement: adım 2, 2 resimden 1. Razor A Handle Grips Replacement: adım 2, 2 resimden 2.
    • Soak the replacement handle grips in warm water for 2-3 minutes.
    • The longer you soak the handle grips in water, the larger they get. Soaking the handle grips for a long time will not damage them.
  3. Razor A Handle Grips Replacement: adım 3, 2 resimden 1. Razor A Handle Grips Replacement: adım 3, 2 resimden 2.
    • Each handle grip should now slide onto the T-tube with ease. If not, soak the handle grip(s) in warm water for another 1-3 minutes.
    • Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
    • Repeat for the other handle grip if installing both.
    • Let the handle grips dry for 24 hours before use.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Jordyn
565 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G13
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
Mathew Sam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 5,056
