Ana içeriğe geç
Razor A Wheel Replacement
Neye ihtiyacın var
    1. Razor A Wheel Replacement, Wheel: adım 1, 1 resimden 1.
      • Flip the scooter upside-down with the handlebars and brake on the ground.
      FixBot'a Sor
      Yorum Ekle
    2. Razor A Wheel Replacement: adım 2, 2 resimden 1. Razor A Wheel Replacement: adım 2, 2 resimden 2.
      • Grab two 3/16" Allen wrenches. Insert one in each screw on the sides of the wheel. Hold one screw in place while turning the other in a counter-clockwise direction, loosening the screw.
      • Once both screws are removed the wheel should be free and fall out.
      • One of the screws fits inside the other. The inner screw should be 5.6 mm in length. During reassembly, the screws can be put back in on either side.
      • During reassembly, do not over-tighten the screws, as you could strip them. They should be just tight enough to prevent the wheel from wobbling.
      FixBot'a Sor
      Yorum Ekle
    3. Razor A Wheel Replacement: adım 3, 2 resimden 1. Razor A Wheel Replacement: adım 3, 2 resimden 2.
      • When replacing a wheel, look for a metal sleeve in the center of the bearing that may be out of line. Forcing a screw through a sleeve that is out of line could ruin the wheel.
      • Remove any obstructions inside the bearing of the new wheel, and move the inner sleeve in the bearing with an Allen key so that the screws can slide into the bearing freely.
      • Put the replacement wheel into place in the scooter frame.
      • For extra security, you can add a small amount of threadlocker glue to the the bolt and tighten it just until until it doesn't fall off or lock the wheel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jordyn
565 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G13
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 89
Her zaman: 14,301
