Ana içeriğe geç
Razor AW Kick Wheel Bar Replacement
Neye ihtiyacın var
  1. Razor AW Kick Wheel Bar Replacement, Wheel Bar: adım 1, 3 resimden 1. Razor AW Kick Wheel Bar Replacement, Wheel Bar: adım 1, 3 resimden 2. Razor AW Kick Wheel Bar Replacement, Wheel Bar: adım 1, 3 resimden 3.
    • Place the scooter on its side and on the ground.
    • Place the 5 mm Hex Security key into the screw, and secure the other side of the screw with another 5 mm Hex Security key to keep it from spinning around.
    • Remove the screw using the 5 mm Hex Security key.
    • Remove the screw from the scooter frame.
  2. Razor AW Kick Wheel Bar Replacement: adım 2, 3 resimden 1. Razor AW Kick Wheel Bar Replacement: adım 2, 3 resimden 2. Razor AW Kick Wheel Bar Replacement: adım 2, 3 resimden 3.
    • Remove the wheel from the scooter slowly.
    • Remove the black wheel holders from the scooter frame.
  3. Razor AW Kick Wheel Bar Replacement: adım 3, 2 resimden 1. Razor AW Kick Wheel Bar Replacement: adım 3, 2 resimden 2.
    • Remove the wheel bar from the scooter frame.
Sonuç
To reassemble your device, follow these instructions in revise order.
Alexander Vazquez
97 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-5, Briggs Fall 2022 CSU Los Angeles, Team 1-5, Briggs Fall 2022 üyesi
CSULA-BRIGGS-F22S1G5
1 Üye
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 236
