Ana içeriğe geç
Razor Hovertrax 2.0 Anti-Slip Pads Replacement
Neye ihtiyacın var
  1. Razor Hovertrax 2.0 Anti-Slip Pads Replacement, Anti-Slip Pads: adım 1, 1 resimden 1.
    • Choose an area to access and slip the Jimmy blade to pry open the pad.
    • We recommend prying the pad open from the top and bottom instead of the sides due to the plastic wheel cover blocking the access point.
  2. Razor Hovertrax 2.0 Anti-Slip Pads Replacement: adım 2, 1 resimden 1.
    • After using the Jimmy tool to open up the area, use your hands and slowly peel off the adhesive from the pad and board.
    • You may be required to remove the remaining adhesive on the board.
Sonuç
Dang Nguyen
217 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 29
