Giriş
This guide is intended to show you how to replace the bushings on a RazorX DLX Electric Skateboard. This guide can be used for other standard skateboards as well. The bushings on a skateboard allow the user to turn and pivot correctly. Using the skateboard with worn or damaged bushings may make it unsafe to use. There are a variety of replacement bushings that range from soft to hard, soft bushings require less effort to turn while harder bushings require more effort. The level of softness used for the replacement will be dependent on the user. Before you start, make sure the power button is switched to off.
Neye ihtiyacın var
Flip the skateboard onto its side.
Use a 13 mm socket wrench to remove the nut that holds the wheel onto the trucks.
Pull the wheel off.
See the first photo for the order of reassembly.
Place one washer onto the trucks first.
Place the wheel with your bearings in place onto the trucks, with the face of the wheel outward.
Place the next washer on the trucks.
Place the nut on the trucks, and tighten using a 13mm socket wrench.
Orient the skateboard so that you have access to the four 32 mm bolts and the nuts that hold them in place,
Remove the four 32 mm bolts with a 3 mm Allen key while holding the nut in place.
