Ana içeriğe geç
Rear Cover Removal
Neye ihtiyacın var
  1. Rear Cover Removal, Rear Cover: adım 1, 1 resimden 1.
    • First ensure your laptop is turned off and check if you have the necessary tools
  2. Rear Cover Removal: adım 2, 2 resimden 1. Rear Cover Removal: adım 2, 2 resimden 2.
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
  3. Rear Cover Removal: adım 3, 3 resimden 1. Rear Cover Removal: adım 3, 3 resimden 2. Rear Cover Removal: adım 3, 3 resimden 3.
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
  4. Rear Cover Removal: adım 4, 1 resimden 1.
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
  5. Rear Cover Removal: adım 5, 3 resimden 1. Rear Cover Removal: adım 5, 3 resimden 2. Rear Cover Removal: adım 5, 3 resimden 3.
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
  6. Rear Cover Removal: adım 6, 1 resimden 1.
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Nelson Oliveira
741 İtibar
4 adet Kılavuz yazıldı
Ekip
jp.ik jp.ik üyesi
Business
2 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
HI, nice job, to remove the keyboard is it necessary remove the motherboard?
Pedro - Yanıt
No, do not need. Just need to remove battery. Very soon I will post a new instruction how to do it. Be insure to don't perfurate or blend the battery. It is fixed with a double tape.
Nelson Oliveira - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 231
