Ana içeriğe geç
Giriş
This guide will show how to reconnect the foot support to the wheelchair after it has fallen off.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
  1. Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height. Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height. Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
    • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
  2. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Screw in the bolt to the top socket to secure the height of the footrest.
    • Screw in the bolt to the top socket to secure the height of the footrest.
  4. Screw in the bolt attaching the footrest to the frame. Screw in the lower bolt to the footrest.
    • Screw in the bolt attaching the footrest to the frame.
    • Screw in the lower bolt to the footrest.
Sonuç
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Kali Slaughter
207 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G8
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 534
