Ana içeriğe geç
Recharging A/C Refrigerant for 2016 Hyundai Elantra
Neye ihtiyacın var
  1. Recharging A/C Refrigerant for 2016 Hyundai Elantra, Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 1, 1 resimden 1.
    • Get refrigerant and read the pressure chart carefully. This is located on the side of the can.
  2. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 2, 3 resimden 1. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 2, 3 resimden 2. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 2, 3 resimden 3.
    • Find and pull the lever to the hood on the driver's side of the vehicle.
  3. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 3, 3 resimden 1. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 3, 3 resimden 2. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 3, 3 resimden 3.
    • Lift the hood while pulling the lever under the center of the hood. Next, prop up the hood with the hood strut.
  4. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 4, 2 resimden 1. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 4, 2 resimden 2.
    • Locate the low-pressure port by following the low-pressure hose (the cap will have an "L" on it).
  5. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 5, 2 resimden 1. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 5, 2 resimden 2.
    • Shake the can well.
  6. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 6, 1 resimden 1.
    • Connect the refrigerant hose to the low-pressure port.
  7. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 7, 1 resimden 1.
    • Start the vehicle and turn on the A/C all the way on.
  8. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 8, 3 resimden 1. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 8, 3 resimden 2. Recharging A/C Refrigerant for 2016 Hyundai Elantra: adım 8, 3 resimden 3.
    • While tipping the can 90 degrees back and forth, fill your vehicle (until the gauge reads as the can specifies).
Sonuç
To recharge your vehicle, follow these instructions in order.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 26
Son 7 gün: 134
Son 30 gün: 527
Her zaman: 7,043
