Ana içeriğe geç
RedOctane X-Plorer Keys Replacement
Neye ihtiyacın var
  1. RedOctane X-Plorer Keys Replacement, Rear Case: adım 1, 2 resimden 1. RedOctane X-Plorer Keys Replacement, Rear Case: adım 1, 2 resimden 2.
    • Remove the strap by pulling it off of the mounts located on the body and neck.
    FixBot'a Sor
    Yorum Ekle
  2. RedOctane X-Plorer Keys Replacement: adım 2, 3 resimden 1. RedOctane X-Plorer Keys Replacement: adım 2, 3 resimden 2. RedOctane X-Plorer Keys Replacement: adım 2, 3 resimden 3.
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
    FixBot'a Sor
    Yorum Ekle
  3. RedOctane X-Plorer Keys Replacement: adım 3, 3 resimden 1. RedOctane X-Plorer Keys Replacement: adım 3, 3 resimden 2. RedOctane X-Plorer Keys Replacement: adım 3, 3 resimden 3.
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
    FixBot'a Sor
    Yorum Ekle
  4. RedOctane X-Plorer Keys Replacement, Keys: adım 4, 3 resimden 1. RedOctane X-Plorer Keys Replacement, Keys: adım 4, 3 resimden 2. RedOctane X-Plorer Keys Replacement, Keys: adım 4, 3 resimden 3.
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
    FixBot'a Sor
    Yorum Ekle
  5. RedOctane X-Plorer Keys Replacement: adım 5, 1 resimden 1.
    • Using your fingers, remove the rubber pad to expose the colored keys.
    FixBot'a Sor
    Yorum Ekle
  6. RedOctane X-Plorer Keys Replacement: adım 6, 2 resimden 1. RedOctane X-Plorer Keys Replacement: adım 6, 2 resimden 2.
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ashley Slocum
228 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G1
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 38
Her zaman: 4,848
