Giriş
The RJ-14 connector is designed to connect to pedals that do not come with the device. This guide will show you how to replace the RJ-14 connector located at the bottom of the guitar.
Neye ihtiyacın var
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
Lift the RJ-14 connector to remove it from the case.
Neredeyse bitti!
Sonuç
