Ana içeriğe geç
RedOctane X-Plorer Rubber Button Strip Replacement
Neye ihtiyacın var
  1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: adım 1, 2 resimden 1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: adım 1, 2 resimden 2.
    • Remove the controller's strap, which will be attached at the points in the red circles.
    • If your controller does not have a strap, move to the next step.
  2. RedOctane X-Plorer Rubber Button Strip Replacement: adım 2, 1 resimden 1.
    • Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
    • Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
  3. RedOctane X-Plorer Rubber Button Strip Replacement: adım 3, 2 resimden 1. RedOctane X-Plorer Rubber Button Strip Replacement: adım 3, 2 resimden 2.
    • Using your hands, remove the body shell.
  4. RedOctane X-Plorer Rubber Button Strip Replacement: adım 4, 1 resimden 1.
    • Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
  5. RedOctane X-Plorer Rubber Button Strip Replacement: adım 5, 2 resimden 1. RedOctane X-Plorer Rubber Button Strip Replacement: adım 5, 2 resimden 2.
    • Using your hands, remove the top shell of neck.
  6. RedOctane X-Plorer Rubber Button Strip Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Flathead 1.5 mm Screwdriver
    $5.49
    Satın Al
    • Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
    • Do not remove the other (right-side) screw on key sensor board, as this can cause damage to the circuitry.
  7. RedOctane X-Plorer Rubber Button Strip Replacement: adım 7, 2 resimden 1. RedOctane X-Plorer Rubber Button Strip Replacement: adım 7, 2 resimden 2.
    • Using your hands, remove the rubber button strip.
  8. RedOctane X-Plorer Rubber Button Strip Replacement: adım 8, 2 resimden 1. RedOctane X-Plorer Rubber Button Strip Replacement: adım 8, 2 resimden 2.
    • Using your hands, insert the replacement strip underneath the key sensor board.
  9. RedOctane X-Plorer Rubber Button Strip Replacement: adım 9, 2 resimden 1. RedOctane X-Plorer Rubber Button Strip Replacement: adım 9, 2 resimden 2.
    • Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
    • The first button will be "A" on Xbox and Wii, and "X" on Playstation.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 251
