Ana içeriğe geç
RedOctane X-Plorer Strum Bar Replacement
Neye ihtiyacın var
  1. RedOctane X-Plorer Strum Bar Replacement, Rear Case: adım 1, 2 resimden 1. RedOctane X-Plorer Strum Bar Replacement, Rear Case: adım 1, 2 resimden 2.
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Strum Bar Replacement: adım 2, 3 resimden 1. RedOctane X-Plorer Strum Bar Replacement: adım 2, 3 resimden 2. RedOctane X-Plorer Strum Bar Replacement: adım 2, 3 resimden 3.
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Strum Bar Replacement: adım 3, 3 resimden 1. RedOctane X-Plorer Strum Bar Replacement: adım 3, 3 resimden 2. RedOctane X-Plorer Strum Bar Replacement: adım 3, 3 resimden 3.
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Strum Bar Replacement, Strum Bar: adım 4, 1 resimden 1.
    • Using two hands, gently remove the two string rod fixtures.
  5. RedOctane X-Plorer Strum Bar Replacement: adım 5, 1 resimden 1.
    • Lift up on the strum bar to remove it from the guitar.
  6. RedOctane X-Plorer Strum Bar Replacement: adım 6, 2 resimden 1. RedOctane X-Plorer Strum Bar Replacement: adım 6, 2 resimden 2.
    • Remove the string rod by gently pulling it out of the strum bar.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jared McMullen
276 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G1
3 Üyeler
9 adet Kılavuz yazıldı
2 Yorum
This did not help.
michelle Coronel - Yanıt
I had a squeaking strum bar so I followed this guide to dismantle and clean the parts. Other than the one step missed in the guide it was easy to follow. It also stopped the squeaking!
Zachary Avery - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 50
Her zaman: 3,602
