Ana içeriğe geç
RedOctane X-Plorer Whammy Bar Replacement
Neye ihtiyacın var
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: adım 1, 2 resimden 1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: adım 1, 2 resimden 2.
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: adım 2, 3 resimden 1. RedOctane X-Plorer Whammy Bar Replacement: adım 2, 3 resimden 2. RedOctane X-Plorer Whammy Bar Replacement: adım 2, 3 resimden 3.
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: adım 3, 3 resimden 1. RedOctane X-Plorer Whammy Bar Replacement: adım 3, 3 resimden 2. RedOctane X-Plorer Whammy Bar Replacement: adım 3, 3 resimden 3.
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: adım 4, 3 resimden 1. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: adım 4, 3 resimden 2. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: adım 4, 3 resimden 3.
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: adım 5, 1 resimden 1.
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: adım 6, 2 resimden 1. RedOctane X-Plorer Whammy Bar Replacement: adım 6, 2 resimden 2.
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: adım 7, 1 resimden 1.
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: adım 8, 1 resimden 1.
    • Using two hands, remove the spring from the plastic tabs.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
[deleted]
175 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 27
Son 30 gün: 110
Her zaman: 3,636
