Ana içeriğe geç
RedOctane X-Plorer Whammy Bar Sensor Replacement
Neye ihtiyacın var
  1. RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: adım 1, 2 resimden 1. RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: adım 1, 2 resimden 2.
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 2, 3 resimden 1. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 2, 3 resimden 2. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 2, 3 resimden 3.
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 3, 3 resimden 1. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 3, 3 resimden 2. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 3, 3 resimden 3.
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: adım 4, 3 resimden 1. RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: adım 4, 3 resimden 2. RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: adım 4, 3 resimden 3.
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 5, 2 resimden 1. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 5, 2 resimden 2.
    • Using one hand, remove the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Sensor Replacement: adım 6, 1 resimden 1.
    • Using two hands, remove the whammy bar sensor.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Riley
649 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G1
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 938
