Giriş
The whammy bar sensor is directly responsible for the performance of the whammy bar. This guide demonstrates how to remove the whammy bar sensor and diagnose issues with the whammy bar that were not obvious from its removal.
Neye ihtiyacın var
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the two 7mm Phillips #0 screws.
Using your fingers, remove the black wire retainer.
Bir başkası bu kılavuzu tamamladı.
