Ana içeriğe geç
Redmi A3 Screen Replacement
Neye ihtiyacın var
    1. Redmi A3 Screen Replacement, Remove SIM: adım 1, 1 resimden 1.
      • Remove the SIM slot so that it doesn't break when you take the phone apart
      FixBot'a Sor
      Yorum Ekle
    2. Redmi A3 Screen Replacement, Heat the adhesive: adım 2, 1 resimden 1.
      • Heat the edges of the back cover and the area of the camera cover using your heat gun, heating pad, or hair dryer
      • If using a hair dryer, be careful, because it's obviously quite imprecise
      FixBot'a Sor
      Yorum Ekle
    3. Redmi A3 Screen Replacement, Pry open the back cover: adım 3, 1 resimden 1.
      • Insert a thin piece of plastic under the back cover and pry it open by dragging the plastic around the edges and carefully under the camera cover
      • If the adhesive is too tough, heat it up again
      FixBot'a Sor
      Yorum Ekle
    4. Redmi A3 Screen Replacement, Remove back cover: adım 4, 1 resimden 1.
      • Carefully remove the back cover of your phone
      • If the back cover is glass, it's better to use a suction cup or a piece of duct tape to avoid cracking
      • Remove the remaining adhesive using adhesive remover or by carefully scraping it off (I forgot to do that initially)
      FixBot'a Sor
      Yorum Ekle
    5. Redmi A3 Screen Replacement, Unscrew frame: adım 5, 3 resimden 1. Redmi A3 Screen Replacement, Unscrew frame: adım 5, 3 resimden 2. Redmi A3 Screen Replacement, Unscrew frame: adım 5, 3 resimden 3.
      • Using a small phillips screwdriver, unscrew the frame of the phone
      • Be careful not to lose any of the screws
      FixBot'a Sor
      Yorum Ekle
    6. Redmi A3 Screen Replacement, Remove frame: adım 6, 2 resimden 1. Redmi A3 Screen Replacement, Remove frame: adım 6, 2 resimden 2.
      • The frame of your phone should come off fairly easily
      • CAREFUL! You probably know this already, but the lock button is the fingerprint sensor; don't forget to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    7. Redmi A3 Screen Replacement, Remove battery: adım 7, 3 resimden 1. Redmi A3 Screen Replacement, Remove battery: adım 7, 3 resimden 2. Redmi A3 Screen Replacement, Remove battery: adım 7, 3 resimden 3.
      • Disconnect the battery (you can do it with your fingers, I'm just using the screwdriver as a pointer)
      • This is a bit tricky: the orange sticker on the battery is separated into two parts labelled A (sides) and B (middle). Peel off the sticker and pull on A
      • Remove the battery with the rest of the sticker. Do not throw the sticker away
      FixBot'a Sor
      Yorum Ekle
    8. Redmi A3 Screen Replacement, Disconnect screen: adım 8, 2 resimden 1. Redmi A3 Screen Replacement, Disconnect screen: adım 8, 2 resimden 2.
      • There are two spots where the screen is connected, don't forget to unplug both cables
      FixBot'a Sor
      Yorum Ekle
    9. Redmi A3 Screen Replacement, Remove screen: adım 9, 2 resimden 1. Redmi A3 Screen Replacement, Remove screen: adım 9, 2 resimden 2.
      • Similarly to the back cover, heat the adhesive and pry the screen off the phone
      • If your screen is as badly cracked as mine, put duct tape all over it to avoid injury (I didn't do that)
      • Remove the remaining adhesive from the phone
      FixBot'a Sor
      Yorum Ekle
    10. Redmi A3 Screen Replacement, Glue and connect new screen: adım 10, 2 resimden 1. Redmi A3 Screen Replacement, Glue and connect new screen: adım 10, 2 resimden 2.
      • Carefully apply a small but substantial amount of phone adhesive around the edges of the phone. Make sure not to touch the front camera
      • Put the new screen on the phone
      • Connect the screen
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Do not forget that the back cover is also glued to the phone around the camera. It's recommended that you wait for several hours (preferably 48) for the adhesive to cure.
7 farklı kişi bu kılavuzu tamamladı.
Nicky C.
406 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 56
Son 30 gün: 228
Her zaman: 1,296
