Ana içeriğe geç
Redmi Note 4 Global Display Replacement
Neye ihtiyacın var
  1. Redmi Note 4 Global Display Replacement, Display: adım 1, 2 resimden 1. Redmi Note 4 Global Display Replacement, Display: adım 1, 2 resimden 2.
    • Use a pin to remove the SIM & SD card
    FixBot'a Sor
    Yorum Ekle
  2. Redmi Note 4 Global Display Replacement: adım 2, 3 resimden 1. Redmi Note 4 Global Display Replacement: adım 2, 3 resimden 2. Redmi Note 4 Global Display Replacement: adım 2, 3 resimden 3.
    • With the help of a silicone spatula or similar opening tool, press gently into the separation between housing and screen
    • Gently pry the frame away from the screen .
    FixBot'a Sor
    Yorum Ekle
  3. Redmi Note 4 Global Display Replacement: adım 3, 1 resimden 1.
    • Disconnect the rest of all the connectors. (Image shows fingerprint scanner connector already removed)
    FixBot'a Sor
    Yorum Ekle
  4. Redmi Note 4 Global Display Replacement: adım 4, 3 resimden 1. Redmi Note 4 Global Display Replacement: adım 4, 3 resimden 2. Redmi Note 4 Global Display Replacement: adım 4, 3 resimden 3.
    • First disconnect the connector for the fingerprint scanner
    • Then carefully pry the scanner (it is adhered to the board )
    • Preheating the scanner area with a hair dryer can help
    FixBot'a Sor
    Yorum Ekle
  5. Redmi Note 4 Global Display Replacement: adım 5, 1 resimden 1.
    • Remove all Phillips screws screws eg with a #00 Phillips driver
    FixBot'a Sor
    Yorum Ekle
  6. Redmi Note 4 Global Display Replacement: adım 6, 1 resimden 1.
    • Remove the rest of the screws
    • Gently pry off the plastic covers
    FixBot'a Sor
    Yorum Ekle
  7. Redmi Note 4 Global Display Replacement: adım 7, 2 resimden 1. Redmi Note 4 Global Display Replacement: adım 7, 2 resimden 2.
    • Remove the plastic cover from the top of the phone
    • Gentle prying may be help to loosen it.
    • Remove the screw hidden under the cover.
    FixBot'a Sor
    Yorum Ekle
  8. Redmi Note 4 Global Display Replacement: adım 8, 2 resimden 1. Redmi Note 4 Global Display Replacement: adım 8, 2 resimden 2.
    • Move the plastic tab to the side to remove the main board
    FixBot'a Sor
    Yorum Ekle
  9. Redmi Note 4 Global Display Replacement: adım 9, 2 resimden 1. Redmi Note 4 Global Display Replacement: adım 9, 2 resimden 2.
    • Disconnect the ribbon cable
    • Remove the screw.
    • Carefully remove the circuit board
    FixBot'a Sor
    Yorum Ekle
  10. Redmi Note 4 Global Display Replacement: adım 10, 2 resimden 1. Redmi Note 4 Global Display Replacement: adım 10, 2 resimden 2.
    • Gently separate the side button bar from the frame
    FixBot'a Sor
    Yorum Ekle
  11. Redmi Note 4 Global Display Replacement: adım 11, 2 resimden 1. Redmi Note 4 Global Display Replacement: adım 11, 2 resimden 2.
    • Remove the upper speaker
    • Caution: When removing the speaker, the two parts of the speaker can separate from each other. They are only held together by two very thin copper cables!
    • The best way to get to the bottom of the speaker and pry it out carefully is by using the direction of the red arrow.
    FixBot'a Sor
    Yorum Ekle
  12. Redmi Note 4 Global Display Replacement: adım 12, 2 resimden 1. Redmi Note 4 Global Display Replacement: adım 12, 2 resimden 2.
    • Peel off the two battery adhesive strips to remove the battery
    • Pull as flat as possible and rather slowly. Heating the display with a hair dryer makes the whole thing a little easier.
    FixBot'a Sor
    Yorum Ekle
  13. Redmi Note 4 Global Display Replacement: adım 13, 1 resimden 1.
    • Disconnect the ribbon cable for the charging board. Keep it safe for later reuse.
    FixBot'a Sor
    Yorum Ekle
  14. Redmi Note 4 Global Display Replacement: adım 14, 2 resimden 1. Redmi Note 4 Global Display Replacement: adım 14, 2 resimden 2.
    • Depending on the completeness of the replacement part, the LED lighting may also be removed
    • T o remove it, gently pry with some pointed tweezers or similar tool
    FixBot'a Sor
    Yorum Ekle
  15. Redmi Note 4 Global Display Replacement, First Test: adım 15, 2 resimden 1. Redmi Note 4 Global Display Replacement, First Test: adım 15, 2 resimden 2.
    • For testing purposes, the button bar, the screen and the battery can be connected.
    • Attention! When doing so, there is an increased risk of damaging the connections or the battery. Be very careful!
    • A long press on the bottom button should start the phone
    FixBot'a Sor
    Yorum Ekle
  16. Redmi Note 4 Global Display Replacement: adım 16, 1 resimden 1.
    • Insert the upper speaker and press it into the end position
    FixBot'a Sor
    Yorum Ekle
  17. Redmi Note 4 Global Display Replacement: adım 17, 1 resimden 1.
    • If previously removed, insert the LED bar (red circle)
    • Insert the charging board into proper position and tighten (blue circle)
    FixBot'a Sor
    Yorum Ekle
  18. Redmi Note 4 Global Display Replacement: adım 18, 1 resimden 1.
    • Remove the blue protective strip from the corresponding adhesive surface. Insert the ribbon cable into the power supply
    • Press the cable flat onto the adhesive area
    • Ensure everything is properly aligned
    FixBot'a Sor
    Yorum Ekle
  19. Redmi Note 4 Global Display Replacement: adım 19, 1 resimden 1.
    • Install the lower plastic cover and screw it in place
    FixBot'a Sor
    Yorum Ekle
  20. Redmi Note 4 Global Display Replacement: adım 20, 3 resimden 1. Redmi Note 4 Global Display Replacement: adım 20, 3 resimden 2. Redmi Note 4 Global Display Replacement: adım 20, 3 resimden 3.
    • Insert the motherboard
    • Use the metal pin and the plastic hook to check proper alignment.
    FixBot'a Sor
    Yorum Ekle
  21. Redmi Note 4 Global Display Replacement: adım 21, 1 resimden 1.
    • Reconnect all connectors
    FixBot'a Sor
    Yorum Ekle
  22. Redmi Note 4 Global Display Replacement, Replacing the battery: adım 22, 2 resimden 1. Redmi Note 4 Global Display Replacement, Replacing the battery: adım 22, 2 resimden 2.
    • Remove the cover from the two adhesive strips for the battery
    • Insert the battery and reconnect it.
    FixBot'a Sor
    Yorum Ekle
  23. Redmi Note 4 Global Display Replacement: adım 23, 1 resimden 1.
    • Press the fingerprint scanner back into its position.
    • Press the display back into the housing. Done!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repeat the steps in reverse order to reassemble your device.
4 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Frederic
457 İtibar
1 Kılavuz yazıldı
3Kılavuz Yorumları
There are major steps missing between step 14 and step 15. This is not a complete guide on screen replacement.
Don - Yanıt Paylaş
Hi Don, which steps are you missing between 14 and 15 ? Once all parts are removed from the old display one can try the test fit on the new display.
Frederic - Yanıt Paylaş
Watch and pray ,global warming.
Jerry Scott - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 92
Her zaman: 8,354
