Ana içeriğe geç
Redragon Impact M908 Scroll Wheel Replacement
Neye ihtiyacın var
    1. Redragon Impact M908 Scroll Wheel Replacement, TEFLON Feet Pads: adım 1, 3 resimden 1. Redragon Impact M908 Scroll Wheel Replacement, TEFLON Feet Pads: adım 1, 3 resimden 2. Redragon Impact M908 Scroll Wheel Replacement, TEFLON Feet Pads: adım 1, 3 resimden 3.
      • Make sure your mouse is unplugged from all devices.
      • Pick up your mouse and flip it over.
      • Reposition the mouse so that the four feet pads are facing you.
      FixBot'a Sor
      Yorum Ekle
    2. Redragon Impact M908 Scroll Wheel Replacement: adım 2, 3 resimden 1. Redragon Impact M908 Scroll Wheel Replacement: adım 2, 3 resimden 2. Redragon Impact M908 Scroll Wheel Replacement: adım 2, 3 resimden 3.
      • Place the pointed edge of a spudger under the corner of one of the feet pads.
      • Press the tool forward, lifting the foot pad until it is fully removed.
      FixBot'a Sor
      Yorum Ekle
    3. Redragon Impact M908 Scroll Wheel Replacement: adım 3, 1 resimden 1.
      • Repeat the process in step two for the other three feet pads.
      FixBot'a Sor
      Yorum Ekle
    1. Redragon Impact M908 Scroll Wheel Replacement, Scroll Wheel: adım 4, 3 resimden 1. Redragon Impact M908 Scroll Wheel Replacement, Scroll Wheel: adım 4, 3 resimden 2. Redragon Impact M908 Scroll Wheel Replacement, Scroll Wheel: adım 4, 3 resimden 3.
      • Unscrew the right-hand 3mm screw using a Phillips #000 screwdriver.
      • Unscrew the remaining four 4mm screws using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Redragon Impact M908 Scroll Wheel Replacement: adım 5, 2 resimden 1. Redragon Impact M908 Scroll Wheel Replacement: adım 5, 2 resimden 2.
      • Lift the mouse's top and remove it from the bottom.
      • Place the top to the side, out of the way.
      • The top does not need to be fully removed from the base, and it can be set aside with the connecting cables attached.
      FixBot'a Sor
      Yorum Ekle
    3. Redragon Impact M908 Scroll Wheel Replacement: adım 6, 3 resimden 1. Redragon Impact M908 Scroll Wheel Replacement: adım 6, 3 resimden 2. Redragon Impact M908 Scroll Wheel Replacement: adım 6, 3 resimden 3.
      • Identify the scroll wheel in the center of the mouse.
      • Unscrew the 3.5mm screw holding the scroll wheel in place using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Redragon Impact M908 Scroll Wheel Replacement: adım 7, 2 resimden 1. Redragon Impact M908 Scroll Wheel Replacement: adım 7, 2 resimden 2.
      • Lift the scroll wheel and pull it out of the mouse.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Johnson
579 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 16-2, Samson Spring 2026 Texas Tech, Team 16-2, Samson Spring 2026 üyesi
TTU-SAMSON-S26S16G2
5 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 171
