Ana içeriğe geç
Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
Reemplazo de iPod Mini Display
Neye ihtiyacın var
  1. Reemplazo de iPod Mini Display, Bisel Superior: adım 1, 1 resimden 1.
    • Antes de abrir tu iPod, asegúrate de que el interruptor de espera esté en la posición de bloqueo.
  2. Reemplazo de iPod Mini Display: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    Satın Al
    • Inserta con cuidado un destornillador pequeño de cabeza plana o Jimmy en la costura entre la carcasa de metal y la tapa de plástico blanco. Utiliza el destornillador para levantar el bisel superior de plástico blanco. Ten cuidado de no dañar el plástico blando con el destornillador.
    • El bisel superior se sujeta con un adhesivo, por lo que puede ser necesario hacer palanca en varios lugares diferentes para liberar la pieza.
    • Para facilitar este trabajo, calienta el adhesivo con un secador a baja temperatura durante unos segundos.
    You can also gently use a metal spudger to lift up both the top and bottom bezels. Allow only 1/8" of the metal spudger (like the screwdriver in the picture) to get inside to get leverage, before fully lifting the bezel up. Please note where the little "teeth" are underneath the bezels, or you can damage those if you are not careful.
    Also, using too big of a flathead screwdriver can cause damage to the plastic and chips away plastic from where you were trying to pry up the bezels, ruining the look of the iPod.
    Ryan - Yanıt
    There should be a button here for "I did it -- EPIC FAILURE!!" When I put my iPod back together, the components on the mainboard were scraping against the clickwheel, and maybe the battery wasn't in perfect alignment, but the result was that there was a lethal amount of friction when sliding the assembly back into the case. As I was trying to relieve the pressure by tilting the board down using a spudger from the bottom, the top of the display bezel ended up scraping against the casing in such a way that it cracked from the center of the right edge. OUCH!! There goes a $50 repair job and a $40 replacement cost! Bye Bye perfectly working iPod Mini )-;
    There are two safeguards that can be done when reassembling this iPod. First, use a stiff piece of plastic film as a shim and lubricant between the top of the logic board and the top inside of the case, such as anti-static packaging, or the clear bag packaging of Apple display dongles (use an exacto knife to cut a long strip of it). Don't cover the display with the plastic, just the logic board components. Second, instead of pushing down on the assembly from the top or sides of the display which will place dangerous pressure on it, connect a cable to the dock connector and pull on it from the bottom, and pull out the plastic shield deftly and easily after the assembly is in position.
    steadfast I and I - Yanıt
    If it's held on by adhesive, how do I get it back on?
    Cam - Yanıt
    If you have longish fingernails and don't mind ruining them, I found it helpful to run my thumbnail between the plastic and the metal casing before going at it with a screwdriver. The little "teeth" a previous commenter mentioned are at approximately the 1/3 and 2/3 marks on the long edge of the plastic casings.
    rongshifen - Yanıt
    Instead of gouging the end caps out with the flat screwdriver, try hot gluing a piece of wood (I used a tongue depressor-like ‘craft stick’) to the end cap, then just lever the cap out without damaging the aluminum. Removing the stick and the glue from the end caps takes a little patience but can be done without leaving a mark.
    Human - Yanıt
    Don’t use any kind of metal tool to get these plastic caps off. Metal on metal will scratch up the body. I use a thin guitar pick, work it in between the cap and case, then turn it horizontal and slide around enough until you can use your fingernail to pull the cap the rest of the way off. Don’t be aggressive and break off the little fingers on the bottom side of the cap.
    Ken Mastri - Yanıt
    Use plastic picks or the back of an iSesamo tool to get in.
    TheYootz Media Group - Yanıt
    For a newbie, consider removing the bottom bezel first. In case of scratches due to lack of practice and expertise, the bottom bezel usually isn't as visible during usage.
    Using your fingernail, determine which edge would be best for starting. Feel for an edge where the aluminum case is a tiny bit higher then the plastic when pressing down gently on the bezel.
    Only use plastic tools. The plastic picks from Ifixit are good. A plastic spudger may work but it needs a very sharp edge.
    As you work the pick in between the bezel and the aluminum case, note that you can push the pick in more toward the middle of the bezel and much less (1/8") elsewhere. Avoid deep probes at the 1/3 and 2/3 points where plastic clips reside.
    For those who are looking at the suggested timeline and wondering how it is possible, this step alone took me 45 minutes. So, take your time as you see fit.
    YeeWee - Yanıt
    As an alternative to using hot glue: I cut a command strip to the width of the white bezel, then stuck it onto the bezel, then stuck a plastic card on the other side. Then it is easy to pull out the bezels. It is also easy to remove the command strips without damaging the bezel.
    Ian - Yanıt
    I found the bezel parts to be easiest to remove using a scalpel (to pry up) and the blue guitar pick looking things.
    Jonathan Cousins - Yanıt
  3. Reemplazo de iPod Mini Display: adım 3, 1 resimden 1.
    • Levanta el bisel superior del iPod.
    A thinner blade, such as a small pocket knife blade worked for me.
    dean dillon - Yanıt
  4. Reemplazo de iPod Mini Display, Bisel inferior: adım 4, 1 resimden 1.
    Jimmy
    $7.95
    Satın Al
    Again, be mindful and careful of the little white teeth on the underside of the plastic especially the two on the ends of the long sides.
    DITOSP - Yanıt
    I used Stanley knife blade to gently prise both top and bottom plastic covers
    jimbo20039 - Yanıt
    Like I do for the top, I use a thin plastic guitar pick to wedge between the plastic cap and metal case. Once it’s in, turn the pick horizontal (same as the cap) and work it around until you can get your fingernails under it. Also, I believe this cap is made to go on only one way, so maybe mark which edge is front or back
    Ken Mastri - Yanıt
  5. Reemplazo de iPod Mini Display: adım 5, 1 resimden 1.
    • Un pequeño par de pinzas para anillos de presión es la herramienta más fácil para extraer el soporte de retención metálico.
    • También puedes usar un destornillador de punta plana para extraer el soporte de retención metálico debajo del bisel inferior, como se muestra. Puedes liberar el soporte empujando primero los brazos de metal en las esquinas y luego levantando el soporte.
    Be *very* careful on the left hand side. It's almost too easy to scrape the click wheel cable and cause damage to it!
    LambdaCalculus - Yanıt
    I used a circlip tool and for removal and reinsertion. It was fast and easy and avoids bending the part. They are also referred to as snap ring pliers.
    thezazupits - Yanıt
    thezazupits kullanıcısından alıntı:
    There are two kinds of snap ring pliers available. One pivots like regular pliers, one hinges in reverse (when you squeeze the handles, the tips spread). Use the first type.
    PZencak - Yanıt
    My click wheel lost some of its functionality. The back button, and the touch sensitivity to scroll through songs isn't working. :(
    coombsnahuel - Yanıt
    Hi,
    I have followed this very good tutorial as carefully as I could and I thank you very much for having posted it!
    However, my problem is not solved. After having connect-disconnect issues when used with car charger, the iPod started making faint noise when plugged and refused to charge or start-up. I thought it was a mechanical noise (hard drive?) but obviously it is not the case because battery and hard drive are now unplugged, and the board-screen assembly still makes the same noise when plugged in a USB socket (but of course I can't localize the origin of that noise).
    Do you have any idea what it might be due to?
    Thank you in advance for any advice,
    Maxime
    Maxime Gommeaux - Yanıt
    I would definitely recommend either circlip pliers to take out the metal retaining bracket because using a screwdriver leaves obvious marks on he corners of the case. I have noticed many for sale on eBay that have these marks. There are now plastic 'lifters' available to remove the top and bottom bezels and these are brilliant if used carefully and go in easily on the click wheel / screen side but be aware that when removing the bottom bezel it may bend the case a bit but it is easily persuaded back into shape. I too have carried out 64 GB, 128 GB and 256 GB conversions to the mini with a compact flash to SD card adapter and before fitting I format the card in my Sony Alpha 350 camera and it works a treat. My daughter loves her 128 gb converted mini and it's almost bombproof with a solid state memory on board.
    ptrmayhew6 - Yanıt
    Rather than pry the ends of the clip out, insert the flat screwdriver as shown ( maybe a little more straight up) and slide it toward the open end, lifting as you go, and the corner of the clip will pop right out.
    Human - Yanıt
    This is possibly the hardest part of this job for me. Getting this metal spring clip out without damaging the ribbon cable that’s right under one side is tricky. Take your time and use care to avoid touching the cable.
    Ken Mastri - Yanıt
    In my ‘repair’, I managed to do the above on the side away from the clickwheel connector. I pried it up, and gently wiggled it free from the space. That way you don’t need to go prying at the connector, at cost of causing some scrape marks on the inside of the casing. Rather have internal scrapes than needing to replace the clickwheel!
    Casey - Yanıt
  6. Reemplazo de iPod Mini Display: adım 6, 1 resimden 1.
    • Levanta el soporte de retención de metal para extraerlo del iPod.
  7. Reemplazo de iPod Mini Display, Monitor: adım 7, 1 resimden 1.
    • Ten cuidado, este conector es frágil.
    • Usa un spudger o la punta de su dedo para desconectar con cuidado la cinta naranja de la rueda de clic de la placa lógica.
  8. Reemplazo de iPod Mini Display: adım 8, 1 resimden 1.
    • Quita los dos tornillos # 00 Phillips que sujetan el conector para auriculares a la carcasa.
  9. Reemplazo de iPod Mini Display: adım 9, 1 resimden 1.
    • Desliza con cuidado el iPod para sacarlo de su carcasa presionando la placa lógica cerca del borde inferior de la rueda de clic.
    • No tires de la placa de la toma de auriculares en la parte superior del iPod, ya que el conector de la placa lógica es frágil.
  10. Reemplazo de iPod Mini Display: adım 10, 1 resimden 1.
    • Después de empujar la placa lógica hacia afuera lo suficiente, sujeta suavemente la placa lógica a ambos lados de la pantalla y continúa deslizando el iPod fuera de su carcasa.
  11. Reemplazo de iPod Mini Display: adım 11, 1 resimden 1.
    • Levanta la batería de la placa lógica y colócala a un lado del iPod.
  12. Reemplazo de iPod Mini Display: adım 12, 1 resimden 1.
    • Usa un spudger para levantar la pestaña de plástico negro que sostiene la cinta naranja de la pantalla en su lugar. La pestaña negra girará 90 grados hacia arriba, liberando el cable plano.
  13. Reemplazo de iPod Mini Display: adım 13, 1 resimden 1.
    • Observa la ubicación de las cuatro pestañas de plástico blancas que sujetan la pantalla a la placa lógica. Estas pestañas deben liberarse antes de poder quitar la pantalla.
  14. Reemplazo de iPod Mini Display: adım 14, 1 resimden 1.
    • Usa un spudger o tu dedo para liberar las cuatro pestañas de plástico blancas indicadas en la imagen anterior.
  15. Reemplazo de iPod Mini Display: adım 15, 1 resimden 1.
    • Da la vuelta al iPod.
    • Levanta con cuidado la pantalla y sácala de su conector.
Sonuç
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
26 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
en es
92%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
iRobot
1 İtibar
636 adet Kılavuz yazıldı
Bir Yorum
Hey when I tried to lift up the tab ,it came out flying what to do now ?
Vatsal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 29
Son 30 gün: 148
Her zaman: 37,639
