Giriş
Esta guía le llevará a través del proceso de instalación de la tarjeta inalámbrica en la PlayStation Vita.
Neye ihtiyacın var
Usando un destornillador Phillips # 00, retire los cuatro tornillos de 6,4 mm en la carcasa trasera
Utilizando el extremo puntiagudo del spudger, desconecte los tres conectores del cable de la antena en la parte superior de la tarjeta inalámbrica.
Deruta los cables de la antena de modo que estén fuera de la carcasa de la tarjeta inalámbrica. Ponga los cables lejos.
Para volver a armar el dispositivo, siga estas instrucciones en orden inverso.
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Walter Valiente dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
4 Yorum
i am takig my vita apart (moving all boards/chips into new oled lcd screen/ front part) and am having trouble taking the wifi chip out in order to take out the right button board, the screw closest to the right button board is i think stripped, is there an easy and non harming way to the motherboard of taking that screw out?
Rubber band .
Duck -
umm, just took mine apart and there isnt a card nor a card holder.... what?
Then you have the Wi-Fi only version. Only the model with the 3G modem actually has that slot. This part is the 3G modem module. The actual Wi-Fi chip is on the mainboard not as a separate module.
