Ana içeriğe geç
Reformat SD Card
  1. Reformat SD Card, Reformat SD Card: adım 1, 2 resimden 1. Reformat SD Card, Reformat SD Card: adım 1, 2 resimden 2.
    • Turn the camera on by sliding the switch from the "Off" position to the "On" position. The switch is located above the touchscreen and to the left.
    • The screen will say "Sensor cleaning" once the switch is moved to "On".
    FixBot'a Sor
    Yorum Ekle
  2. Reformat SD Card: adım 2, 1 resimden 1.
    • Push the black button that says "Menu", located below the "ON/OFF" switch.
    FixBot'a Sor
    Yorum Ekle
  3. Reformat SD Card: adım 3, 1 resimden 1.
    • Using the thumb pad, scroll to the 9th menu from the left.
    FixBot'a Sor
    Yorum Ekle
  4. Reformat SD Card: adım 4, 1 resimden 1.
    • Scroll down the list using the thumb pad and select, "Format card" by pressing the center of the thumb pad labeled, "SET".
    FixBot'a Sor
    Yorum Ekle
  5. Reformat SD Card: adım 5, 2 resimden 1. Reformat SD Card: adım 5, 2 resimden 2.
    • Once you select "OK", all pictures will be erased from the SD Card.
    • Press the right side of the thumb pad to move over the "Ok" button.
    • Once "OK" is highlighted, press the middle of thumb pad to initiate the formatting of the card.
    FixBot'a Sor
    Yorum Ekle
  6. Reformat SD Card: adım 6, 1 resimden 1.
    • Wait.
    FixBot'a Sor
    Yorum Ekle
  7. Reformat SD Card: adım 7, 1 resimden 1.
    • SD Card is now formatted.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 1,409
