Ana içeriğe geç
Refrigerator Handle with No Drills Installation
Jaskaran Buttar
Jaskaran Buttar ve 3 diğer katkıda bulunanlar
En son November 4, 2015 tarihinde güncellendi
5 dakika
Çok kolay
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Have you recently broken the handle of your fridge, but don't want to go through the hassle of drilling holes and screwing in bolts? Well, with this guide you will be able to avoid that issue and properly install a cheap and mess free handle.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: adım 1, 3 resimden 1. Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: adım 1, 3 resimden 2. Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: adım 1, 3 resimden 3.
    • Use a clean sponge or damp lint free cloth to apply the handle to the surface.
    • Soapy water or other mild cleansers may be used to clean the surface from all grease or grime.
    • Preferably use cold or luke warm water.
  2. Refrigerator Handle with No Drills Installation: adım 2, 3 resimden 1. Refrigerator Handle with No Drills Installation: adım 2, 3 resimden 2. Refrigerator Handle with No Drills Installation: adım 2, 3 resimden 3.
    • Gently clean the surface of refrigerator where handle will be applied.
    • Ensure the surface is completely dry before application.
  3. Refrigerator Handle with No Drills Installation: adım 3, 3 resimden 1. Refrigerator Handle with No Drills Installation: adım 3, 3 resimden 2. Refrigerator Handle with No Drills Installation: adım 3, 3 resimden 3.
    • Clean the bottom of the handle's suction cups with a damp sponge or lint-free towel.
    • Ensure the surface is completely dry up before application.
  4. Refrigerator Handle with No Drills Installation: adım 4, 1 resimden 1.
    • Once both surfaces are dry, place the handle with suction cups facing the refrigerator.
    • Position the handle on the side you would open the refrigerator.
  5. Refrigerator Handle with No Drills Installation: adım 5, 1 resimden 1.
    • Position the handle vertically and at an appropriate height.
    • The height is up to your own personal preference.
  6. Refrigerator Handle with No Drills Installation: adım 6, 2 resimden 1. Refrigerator Handle with No Drills Installation: adım 6, 2 resimden 2.
    • Apply pressure to both ends of the handle for approximately 15 seconds.
  7. Refrigerator Handle with No Drills Installation: adım 7, 3 resimden 1. Refrigerator Handle with No Drills Installation: adım 7, 3 resimden 2. Refrigerator Handle with No Drills Installation: adım 7, 3 resimden 3.
    • Lock the suction cups in place by pushing down on the hatches.
    • Depending on manufacturer, locking the suction handles may differ in method.
  8. Refrigerator Handle with No Drills Installation: adım 8, 2 resimden 1. Refrigerator Handle with No Drills Installation: adım 8, 2 resimden 2.
    • Slowly release the handle.
    • If handle detaches, repeat steps 4-8 until successful.
Sonuç
Jaskaran Buttar
125 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-7, Green Fall 2015 Cal Poly, Team 10-7, Green Fall 2015 üyesi
CPSU-GREEN-F15S10G7
3 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
Help to fix a big hole where the door is holding on door falling off
Joya Hall - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 273
