Ana içeriğe geç
Remington S5500 Power Supply Cable Removal
Neye ihtiyacın var
  1. Remington S5500 Power Supply Cable Removal, Power Supply Cable: adım 1, 2 resimden 1. Remington S5500 Power Supply Cable Removal, Power Supply Cable: adım 1, 2 resimden 2.
    • Place the prying tool in between the hair straightener and the aligning cap.
    • Push forwards on the prying tool to pop off the aligning cap.
  2. Remington S5500 Power Supply Cable Removal: adım 2, 3 resimden 1. Remington S5500 Power Supply Cable Removal: adım 2, 3 resimden 2. Remington S5500 Power Supply Cable Removal: adım 2, 3 resimden 3.
    • Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
    • Use the prying tool to remove the aligning rods after the removal of the screws.
    • Gently separate each half of the hair straightener.
    • The spring located in the middle of this mechanism may pop out and can get lost very easily. Try to separate the two components slowly.
  3. Remington S5500 Power Supply Cable Removal: adım 3, 2 resimden 1. Remington S5500 Power Supply Cable Removal: adım 3, 2 resimden 2.
    • After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
    • Use the prying tool to remove the hinge cover.
  4. Remington S5500 Power Supply Cable Removal: adım 4, 2 resimden 1. Remington S5500 Power Supply Cable Removal: adım 4, 2 resimden 2.
    • Pull upwards while pulling outwards to disconnect the wire from the housing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Benjamin Yohe
303 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Wilson Summer 2018 IUPUI, Team S3-G3, Wilson Summer 2018 üyesi
IUPUI-WILSON-SU18S3G3
5 Üyeler
6 Yorum
Excelente trabajo! Muchas gracias por la información!
Ronnetto - Yanıt
is there a place where you can buy and replace the power cable, or the plug ?
alexandru popa - Yanıt
the slip ring plug that is ..
alexandru popa -
Hello,
from where did you get the spare power cord ?
Kes - Yanıt
part number would be helpful?
Steven Lamprell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 69
Her zaman: 6,654
