Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to assist with general disassembly or troubleshooting of your braille display.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the four bottom screws with a Phillips #00 screwdriver. Remove the four bottom screws with a Phillips #00 screwdriver.
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset.
    • Remove the plastic cover, paper and chipset.
  3. Remove the two screws with a Phillips #00 screwdriver on the logic board. take out the main circuit like show in the picture take out the main circuit like show in the picture
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  4. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver.
    • Remove the four screws with a Phillips #00 screwdriver.
  5. Remove the connector delicately. Remove the connector delicately. Remove the connector delicately.
    • Remove the connector delicately.
  6. when you put it back together make sure mechanical cells are connected correctly when you put it back together make sure mechanical cells are connected correctly
    • when you put it back together make sure mechanical cells are connected correctly
Sonuç
Sisyphe
332 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 677
