Ana içeriğe geç
Remove IBM WorkPad c3 Battery
Neye ihtiyacın var
  1. Remove IBM WorkPad c3 Battery, Back Case: adım 1, 2 resimden 1. Remove IBM WorkPad c3 Battery, Back Case: adım 1, 2 resimden 2.
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    FixBot'a Sor
    Yorum Ekle
  2. Remove IBM WorkPad c3 Battery: adım 2, 1 resimden 1.
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
    FixBot'a Sor
    Yorum Ekle
  3. Remove IBM WorkPad c3 Battery: adım 3, 2 resimden 1. Remove IBM WorkPad c3 Battery: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    FixBot'a Sor
    Yorum Ekle
  4. Remove IBM WorkPad c3 Battery, Battery: adım 4, 1 resimden 1.
    • Remove the yellow tape that is covering the battery connector
    FixBot'a Sor
    Yorum Ekle
  5. Remove IBM WorkPad c3 Battery: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the tweezers, carefully disconnect the battery cable from the port
    FixBot'a Sor
    Yorum Ekle
  6. Remove IBM WorkPad c3 Battery: adım 6, 2 resimden 1. Remove IBM WorkPad c3 Battery: adım 6, 2 resimden 2.
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Falkenstein
75 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G35
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 4,868
