Ana içeriğe geç
Remove IBM WorkPad c3 Battery
Neye ihtiyacın var
  1. Remove IBM WorkPad c3 Battery, Back Case: adım 1, 2 resimden 1. Remove IBM WorkPad c3 Battery, Back Case: adım 1, 2 resimden 2.
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. Remove IBM WorkPad c3 Battery: adım 2, 1 resimden 1.
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. Remove IBM WorkPad c3 Battery: adım 3, 2 resimden 1. Remove IBM WorkPad c3 Battery: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
  4. Remove IBM WorkPad c3 Battery, Battery: adım 4, 1 resimden 1.
    • Remove the yellow tape that is covering the battery connector
  5. Remove IBM WorkPad c3 Battery: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the tweezers, carefully disconnect the battery cable from the port
  6. Remove IBM WorkPad c3 Battery: adım 6, 2 resimden 1. Remove IBM WorkPad c3 Battery: adım 6, 2 resimden 2.
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Falkenstein
75 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G35
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 4,600
