Ana içeriğe geç
Remove Nintendo GameCube Optical Drive Assembly
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: adım 1, 3 resimden 1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: adım 1, 3 resimden 2. Remove Nintendo GameCube Optical Drive Assembly, Top Case: adım 1, 3 resimden 3.
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Remove Nintendo GameCube Optical Drive Assembly: adım 2, 3 resimden 1. Remove Nintendo GameCube Optical Drive Assembly: adım 2, 3 resimden 2. Remove Nintendo GameCube Optical Drive Assembly: adım 2, 3 resimden 3.
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: adım 3, 2 resimden 1. Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: adım 3, 2 resimden 2.
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
  4. Remove Nintendo GameCube Optical Drive Assembly: adım 4, 2 resimden 1. Remove Nintendo GameCube Optical Drive Assembly: adım 4, 2 resimden 2.
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
  5. Remove Nintendo GameCube Optical Drive Assembly: adım 5, 2 resimden 1. Remove Nintendo GameCube Optical Drive Assembly: adım 5, 2 resimden 2.
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
  6. Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: adım 6, 3 resimden 1. Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: adım 6, 3 resimden 2. Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: adım 6, 3 resimden 3.
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
Sonuç
dcarlin
366 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G2
4 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 4,406
