Ana içeriğe geç
Remove PowerMac G4 M5183 Main Fan
Neye ihtiyacın var
  1. Remove PowerMac G4 M5183 Main Fan, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 1. Remove PowerMac G4 M5183 Main Fan, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 2.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Remove PowerMac G4 M5183 Main Fan, Main Fan: adım 2, 2 resimden 1. Remove PowerMac G4 M5183 Main Fan, Main Fan: adım 2, 2 resimden 2.
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Remove PowerMac G4 M5183 Main Fan: adım 3, 1 resimden 1.
    • Remove the power cable from the fan and detach bracing.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Justin Petrilli
3.114 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G24
4 Üyeler
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 5,438
