Ana içeriğe geç
Remove the Write Protect Screw
Neye ihtiyacın var
  1. Remove the Write Protect Screw, Remove the rubber pads: adım 1, 2 resimden 1. Remove the Write Protect Screw, Remove the rubber pads: adım 1, 2 resimden 2.
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Remove the Write Protect Screw, Removing the bottom panel: adım 2, 3 resimden 1. Remove the Write Protect Screw, Removing the bottom panel: adım 2, 3 resimden 2. Remove the Write Protect Screw, Removing the bottom panel: adım 2, 3 resimden 3.
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Remove the Write Protect Screw, Pop it open: adım 3, 2 resimden 1. Remove the Write Protect Screw, Pop it open: adım 3, 2 resimden 2.
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): adım 4, 2 resimden 1. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): adım 4, 2 resimden 2.
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Kevin Fessler
1.770 İtibar
4 adet Kılavuz yazıldı
4 Yorum
removing this will allow me to boot and install windows?
john Akday - Yanıt
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy -
Acer R752TN write protect screw location?
Fredrik Løvås - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 107
Son 30 gün: 594
Her zaman: 35,684
