Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
How to take apart your 2013 Chromebook Pixel to remove the Write Protect Screw. This will allow you to install other operating systems natively.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip your Chromebook Pixel over onto its back Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Using a small Philips screwdriver, remove the four screws under the pads Using a spudger (or another flat but slightly blunt object), gently pry the laptop open You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Gently pull up from the front of the laptop and open it up like a clamshell Gently pull up from the front of the laptop and open it up like a clamshell
    • Gently pull up from the front of the laptop and open it up like a clamshell
  5. Locate the write protect screw Remove it and you can begin flashing your BIOS!
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    Do I have to flash the bios when replacing the battery?
    Clive Gorman - Yanıt
    There is no need to flash the BIOS if all you want to do is replace the battery.
    Kevin Fessler -
    I want to install windows on to the chrome book pixel 2013 but i have concerns regarding the touch screen. Can you help? Is there any video that you have uploaded for the installation?
    Hari Krishna Bharadw Pudipeddi - Yanıt
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kevin Fessler
1.317 İtibar
4 adet Kılavuz yazıldı
2 Yorum
removing this will allow me to boot and install windows?
john Akday - Yanıt
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 54
Son 30 gün: 328
Her zaman: 8,458
