Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip your Chromebook Pixel over onto its back
Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
Using a small Philips screwdriver, remove the four screws under the pads
Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
Gently pull up from the front of the laptop and open it up like a clamshell
Locate the write protect screw
Remove it and you can begin flashing your BIOS!
15 farklı kişi bu kılavuzu tamamladı.
4 Yorum
removing this will allow me to boot and install windows?
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
You will find more information here:
Acer R752TN write protect screw location?
