Ana içeriğe geç
Removing 1985-1988 Volvo 740 Throttle Body
Neye ihtiyacın var
  1. Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: adım 1, 2 resimden 1. Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: adım 1, 2 resimden 2.
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Removing 1985-1988 Volvo 740 Throttle Body, Removing Throttle Body: adım 2, 1 resimden 1.
    • Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
  3. Removing 1985-1988 Volvo 740 Throttle Body: adım 3, 1 resimden 1.
    • Locate throttle linkage cable assembly.
  4. Removing 1985-1988 Volvo 740 Throttle Body: adım 4, 2 resimden 1. Removing 1985-1988 Volvo 740 Throttle Body: adım 4, 2 resimden 2.
    • Twist the assembly clockwise.
  5. Removing 1985-1988 Volvo 740 Throttle Body: adım 5, 1 resimden 1.
    • Slide both slackened cables off assembly’s guides.
  6. Removing 1985-1988 Volvo 740 Throttle Body: adım 6, 2 resimden 1. Removing 1985-1988 Volvo 740 Throttle Body: adım 6, 2 resimden 2.
    • Locate the two hoses on the top of the throttle body.
    • Gently lift the hoses off.
  7. Removing 1985-1988 Volvo 740 Throttle Body: adım 7, 1 resimden 1.
    • Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
  8. Removing 1985-1988 Volvo 740 Throttle Body: adım 8, 1 resimden 1.
    • Remove the intake tube from the throttle body.
  9. Removing 1985-1988 Volvo 740 Throttle Body: adım 9, 1 resimden 1.
    • Locate wiring clip on the underside of the throttle body.
  10. Removing 1985-1988 Volvo 740 Throttle Body: adım 10, 2 resimden 1. Removing 1985-1988 Volvo 740 Throttle Body: adım 10, 2 resimden 2.
    • Press down on the locking mechanism before gently removing the wiring clip.
  11. Removing 1985-1988 Volvo 740 Throttle Body: adım 11, 3 resimden 1. Removing 1985-1988 Volvo 740 Throttle Body: adım 11, 3 resimden 2. Removing 1985-1988 Volvo 740 Throttle Body: adım 11, 3 resimden 3.
    • Locate throttle linkage arm.
    • Open the locking clip with a flat head screwdriver.
    • Pry off the linkage arm with a flat head screwdriver.
  12. Removing 1985-1988 Volvo 740 Throttle Body: adım 12, 3 resimden 1. Removing 1985-1988 Volvo 740 Throttle Body: adım 12, 3 resimden 2. Removing 1985-1988 Volvo 740 Throttle Body: adım 12, 3 resimden 3.
    • Locate the three 13mm nuts attaching the throttle body to the intake manifold.
    • Remove nuts with a 13mm crescent wrench.
  13. Removing 1985-1988 Volvo 740 Throttle Body: adım 13, 1 resimden 1.
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Raymond
76 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G28
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 4,572
