Ana içeriğe geç
Removing 1994-2001 Acura Integra Center Console
Neye ihtiyacın var
  1. Removing 1994-2001 Acura Integra Center Console, Center Console: adım 1, 2 resimden 1. Removing 1994-2001 Acura Integra Center Console, Center Console: adım 1, 2 resimden 2.
    • Remove the two Phillips screws at the very rear of the center console near the floor.
  2. Removing 1994-2001 Acura Integra Center Console: adım 2, 2 resimden 1. Removing 1994-2001 Acura Integra Center Console: adım 2, 2 resimden 2.
    • Insert a small flathead screwdriver into the notch at the driver's side rear corner of the screw cover directly below the parking brake lever and pry it off.
    • Remove the two Phillips screws that were underneath the screw cover.
  3. Removing 1994-2001 Acura Integra Center Console: adım 3, 2 resimden 1. Removing 1994-2001 Acura Integra Center Console: adım 3, 2 resimden 2.
    • Grab the bottom of the rear portion of the console and lift up and away from the front of the car.
    • Remove the rear portion of the center console.
  4. Removing 1994-2001 Acura Integra Center Console: adım 4, 2 resimden 1. Removing 1994-2001 Acura Integra Center Console: adım 4, 2 resimden 2.
    • Pull the ash tray out from the center console until it stops.
    • Push down on the metal plate at the top of the ash tray and continue to pull the tray out until it is completely removed.
  5. Removing 1994-2001 Acura Integra Center Console: adım 5, 3 resimden 1. Removing 1994-2001 Acura Integra Center Console: adım 5, 3 resimden 2. Removing 1994-2001 Acura Integra Center Console: adım 5, 3 resimden 3.
    • Remove two Phillips screws from behind the ash tray.
    • Remove the lower portion of the console that contains the cigarette lighter from the rest of the center console.
    • Disconnect the electrical connector for the cigarette lighter by first depressing the tab on top, and then pulling directly out of the socket.
  6. Removing 1994-2001 Acura Integra Center Console: adım 6, 3 resimden 1. Removing 1994-2001 Acura Integra Center Console: adım 6, 3 resimden 2. Removing 1994-2001 Acura Integra Center Console: adım 6, 3 resimden 3.
    • Remove four Phillips screws that hold the side pieces of the front portion of the console in place.
    • Two below the radio pocket.
    • Two on the faces of the side pieces, one on either side.
  7. Removing 1994-2001 Acura Integra Center Console: adım 7, 2 resimden 1. Removing 1994-2001 Acura Integra Center Console: adım 7, 2 resimden 2.
    • Remove the shift knob by unscrewing it counter-clockwise.
    • Lift the front portion of the center console up and away from the front of the car.
    • It may be necessary to pull the emergency brake handle up further to create enough room to remove the front portion of the center console.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
David Hodson
150.882 İtibar
127 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 19,210
