Ana içeriğe geç
Removing Braven BRV-X Bottom Outer Casing
Neye ihtiyacın var
  1. Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: adım 1, 3 resimden 1. Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: adım 1, 3 resimden 2. Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: adım 1, 3 resimden 3.
    • Flip the Braven BRV-X upside down so you are facing the bottom side.
    • With the H1.5 Head Screwdriver, unscrew the four screws.
    • All screws on this device can be stripped easily. Hold your screwdriver with the thumb on top and swivel with the opposite hand's thumb and index finger.
    • Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
    • Gently remove the outer casing, which should reveal the inner shell.
  2. Removing Braven BRV-X Bottom Outer Casing: adım 2, 2 resimden 1. Removing Braven BRV-X Bottom Outer Casing: adım 2, 2 resimden 2.
    • With a Jimmy, cut the two warranty seals on either side.
    • You may also use a tech knife instead of a Jimmy.
    • WARNING: Once warranty seals are broken, you may no longer return the product.
    • Next, remove the 18 screws with a #00 Phillips screwdriver.
  3. Removing Braven BRV-X Bottom Outer Casing: adım 3, 2 resimden 1. Removing Braven BRV-X Bottom Outer Casing: adım 3, 2 resimden 2.
    • Using two plastic opening tools, slide under the cover and slowly lift.
    • There is glue nearly all around the inner shell, so strength will be necessary. When both tools are inserted, you can slide out along the edges.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Courtney Crockett
324 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 19-4, Rauch Fall 2015 Texas Tech, Team 19-4, Rauch Fall 2015 üyesi
TTU-RAUCH-F15S19G4
4 Üyeler
Bir Yorum
How do you remove the charging port
Neto - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,564
