Ana içeriğe geç
Removing Creative Zen Vision W Back Cover
Neye ihtiyacın var
  1. Removing Creative Zen Vision W Back Cover, Battery Removal: adım 1, 3 resimden 1. Removing Creative Zen Vision W Back Cover, Battery Removal: adım 1, 3 resimden 2. Removing Creative Zen Vision W Back Cover, Battery Removal: adım 1, 3 resimden 3.
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
    FixBot'a Sor
  2. Removing Creative Zen Vision W Back Cover, Back Cover: adım 2, 1 resimden 1.
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
    FixBot'a Sor
  3. Removing Creative Zen Vision W Back Cover: adım 3, 2 resimden 1. Removing Creative Zen Vision W Back Cover: adım 3, 2 resimden 2.
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
    FixBot'a Sor
  4. Removing Creative Zen Vision W Back Cover: adım 4, 3 resimden 1. Removing Creative Zen Vision W Back Cover: adım 4, 3 resimden 2. Removing Creative Zen Vision W Back Cover: adım 4, 3 resimden 3.
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
    FixBot'a Sor
Sonuç
Gabriele Pregadio
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 56
Her zaman: 1,012
