Ana içeriğe geç
Removing DVD Drive from Acer Aspire 5100
Neye ihtiyacın var
  1. Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: adım 1, 2 resimden 1. Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: adım 1, 2 resimden 2.
    • Locate tab with battery symbol on back of laptop. Slide to left to eject battery.
  2. Removing DVD Drive from Acer Aspire 5100: adım 2, 1 resimden 1.
    • Locate cover on back of laptop, diagonal to battery compartment. Remove four screws securing cover.
  3. Removing DVD Drive from Acer Aspire 5100: adım 3, 2 resimden 1. Removing DVD Drive from Acer Aspire 5100: adım 3, 2 resimden 2.
    • After removing screws, carefully detach cover. You will see the cooling fan in the corner.
  4. Removing DVD Drive from Acer Aspire 5100: adım 4, 2 resimden 1. Removing DVD Drive from Acer Aspire 5100: adım 4, 2 resimden 2.
    • Opposite the cooling fan is the component that contains the RAM card. Remove the screws holding the component in place. Carefully detach the component to expose the RAM card.
  5. Removing DVD Drive from Acer Aspire 5100: adım 5, 1 resimden 1.
    • Locate the DVD drive and remove screw securing drive. Carefully push drive out from laptop.
Sonuç
To reassemble, follow above steps in reverse.
2 farklı kişi bu kılavuzu tamamladı.
luis
167 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-66, Johann Spring 2010 Cal Poly, Team 18-66, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G66
5 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 2,920
