Ana içeriğe geç
Removing Dell Inspiron 1150 Battery Replacement
  1. Removing Dell Inspiron 1150 Battery Replacement, Battery: adım 1, 3 resimden 1. Removing Dell Inspiron 1150 Battery Replacement, Battery: adım 1, 3 resimden 2. Removing Dell Inspiron 1150 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
Teja
98 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G2
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 11,027
