Ana içeriğe geç
Removing Dell Inspiron 1150 Mini Wireless PCI Card
Neye ihtiyacın var
  1. Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: adım 1, 3 resimden 1. Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: adım 1, 3 resimden 2. Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: adım 1, 3 resimden 3.
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Wireless MiniPCI Card.
  2. Removing Dell Inspiron 1150 Mini Wireless PCI Card: adım 2, 2 resimden 1. Removing Dell Inspiron 1150 Mini Wireless PCI Card: adım 2, 2 resimden 2.
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Removing Dell Inspiron 1150 Mini Wireless PCI Card: adım 3, 1 resimden 1.
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
Sonuç
Bir başkası bu kılavuzu tamamladı.
Teja
98 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G2
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 25
Her zaman: 5,983
