Ana içeriğe geç
Removing Dell Inspiron 1150 RAM
Neye ihtiyacın var
  1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: adım 1, 1 resimden 1.
    • Turn the laptop so that the bottom is facing up.
    • Locate the panel that has an M on it and two air vents.
  2. Removing Dell Inspiron 1150 RAM: adım 2, 2 resimden 1. Removing Dell Inspiron 1150 RAM: adım 2, 2 resimden 2.
    • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
    • Put this screw in a bag or easily identifiable place.
    • Remove the panel.
  3. Removing Dell Inspiron 1150 RAM: adım 3, 3 resimden 1. Removing Dell Inspiron 1150 RAM: adım 3, 3 resimden 2. Removing Dell Inspiron 1150 RAM: adım 3, 3 resimden 3.
    • After removing the panel, you will see two memory modules.
    • Locate the four spring clips that are holding the memory modules in place.
    • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
    • Gently raise the memory module and lift it out of its socket.
Sonuç
Christopher
8 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G2
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 25
Her zaman: 5,918
