Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The purpose of this guide is to demonstrate how to locate and remove the 1150 Wireless MiniPCI Card.
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the laptop upside down and  locate the panel labeled C. Unscrew the single screw holding the cover in place. lift up the cover and remove it to exposed the Wireless MiniPCI Card.
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • lift up the cover and remove it to exposed the Wireless MiniPCI Card.
  2. Using a plastic spudger or similar, gently pry the grey and black wires off. The grey and black wires are the antenna wires so be careful not to damage them
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
Sonuç
Bir başkası bu kılavuzu tamamladı.
Teja
98 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 5,615
