Ana içeriğe geç
Removing Dell Inspiron 530 Processor
Neye ihtiyacın var
  1. Removing Dell Inspiron 530 Processor, Side Panel: adım 1, 1 resimden 1.
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Removing Dell Inspiron 530 Processor: adım 2, 1 resimden 1.
    • Slide the side panel towards the back and remove.
  3. Removing Dell Inspiron 530 Processor, Removing Processor: adım 3, 1 resimden 1.
    • Locate the processor's heat sink and fan.
  4. Removing Dell Inspiron 530 Processor: adım 4, 1 resimden 1.
    • Remove the fan's power cable from the motherboard.
  5. Removing Dell Inspiron 530 Processor: adım 5, 1 resimden 1.
    • Locate and unscrew the four Phillips #0 screws at the corners of the fan.
    • The screws will not come out completely.
  6. Removing Dell Inspiron 530 Processor: adım 6, 1 resimden 1.
    • Remove the fan and heat sink.
  7. Removing Dell Inspiron 530 Processor: adım 7, 1 resimden 1.
    • Gently press down and release the silver lever.
  8. Removing Dell Inspiron 530 Processor: adım 8, 1 resimden 1.
    • Open the metal casing over the processor.
  9. Removing Dell Inspiron 530 Processor: adım 9, 1 resimden 1.
    • Gently lift up the processor, holding by the edges only.
Sonuç
Note: For reassembly on step seven, make sure the corner of the processor with the gold triangle is pointing towards the release lever.
14 farklı kişi bu kılavuzu tamamladı.
James Aldag
402 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-8, Regan Fall 2011 Cal Poly, Team 6-8, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G8
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 9,230
