Ana içeriğe geç
Removing Fender Frontman 15r Back panel
Neye ihtiyacın var
  1. Removing Fender Frontman 15r Back panel, Back panel: adım 1, 1 resimden 1.
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Removing Fender Frontman 15r Back panel: adım 2, 1 resimden 1.
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Removing Fender Frontman 15r Back panel: adım 3, 1 resimden 1.
    • Once the top is separated, use your hand to remove the back panel from the unit.
Sonuç
Greg Sawers
85 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G30
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
I need to know where to find a used circuit board for my Fender Frontman 15G. A circuit board from a Fender Frontman 15R will also work. Please help me.
sparkyman401 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 6,651
