Ana içeriğe geç
Removing Front Panel/ Screen Logic Board
Neye ihtiyacın var
    1. Removing Front Panel/ Screen Logic Board, Front panel/ Screen Logic Board: adım 1, 1 resimden 1.
      • Using the plastic opening tool, pry off the top faceplate.
      • Place the tool in the small crack that runs along the side of the phone and pry.
      FixBot'a Sor
      Yorum Ekle
    2. Removing Front Panel/ Screen Logic Board: adım 2, 1 resimden 1.
      • Using the T6 Torx Screwdriver remove all 4 small screws.
      FixBot'a Sor
      Yorum Ekle
    3. Removing Front Panel/ Screen Logic Board: adım 3, 1 resimden 1.
      • Remove silver plate from phone.
      FixBot'a Sor
      Yorum Ekle
    4. Removing Front Panel/ Screen Logic Board: adım 4, 1 resimden 1.
      • Using the spudger remove the plastic camera casing
      FixBot'a Sor
      Yorum Ekle
    5. Removing Front Panel/ Screen Logic Board: adım 5, 1 resimden 1.
      • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
      FixBot'a Sor
      Yorum Ekle
    6. Removing Front Panel/ Screen Logic Board: adım 6, 1 resimden 1.
      • Use Spudger or hands to detach flex cable from front screen logic board
      FixBot'a Sor
      Yorum Ekle
Sonuç
Cecilia
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G96
4 Üyeler
77 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 34
Her zaman: 2,180
