Ana içeriğe geç
Removing HP Pavilion zd8000 WiFi Card Cables
Neye ihtiyacın var
  1. Removing HP Pavilion zd8000 WiFi Card Cables, Battery: adım 1, 1 resimden 1.
    • Slide the battery release latch towards you.
  2. Removing HP Pavilion zd8000 WiFi Card Cables: adım 2, 2 resimden 1. Removing HP Pavilion zd8000 WiFi Card Cables: adım 2, 2 resimden 2.
    • Pull up on the battery to remove it.
  3. Removing HP Pavilion zd8000 WiFi Card Cables, WiFi Card Cables: adım 3, 2 resimden 1. Removing HP Pavilion zd8000 WiFi Card Cables, WiFi Card Cables: adım 3, 2 resimden 2.
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. Removing HP Pavilion zd8000 WiFi Card Cables: adım 4, 2 resimden 1. Removing HP Pavilion zd8000 WiFi Card Cables: adım 4, 2 resimden 2.
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
Sonuç
Allie Menard
820 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-56, Amido Spring 2011 Cal Poly, Team 24-56, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G56
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,345
