Ana içeriğe geç
Removing JuiceBox from the wall
  1. Removing JuiceBox from the wall, Remove mounting screw: adım 1, 1 resimden 1.
    • On most installations, the JuiceBox is held to your wall using one screw between the two cable glands. Remove this screw.
    • After removing the mounting screw, lift JuiceBox straight up (parallel to wall) to unlatch it from the wall mounting tab. If you ever sell/give away JuiceBox, keep this wall mount tab with the box!
    • If your JuiceBox is hardwired, you would instead replace these steps with simply switching-off the breaker in preparation for the relay replacement work. To remove a hardwired unit from the wall, consult an electrician.
Sonuç
Matt Falcon
2.740 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 1,023
